Comet PoE (GL-RM1PE) Overview¶
Appearance¶
Dimension¶
LED¶
There is one LED indicator on the top panel of Comet PoE.
| LED Status | Description |
| Solid Blue | Starting up |
| Flashing White | Started up but No Internet |
| Solid White | Connected to Internet |
| Flashing Blue & White | Firmware Upgrading |
Package Contents¶
- 1 x Comet PoE (GL-RM1PE)
- 1 x User manual
- 1 x Thank you card
- 1 x Ethernet cable
- 1 x HD cable
- 1 x USB cable (Type-A to Type-C)
- 1 x USB cable (Type-C to Type-C)
Check out Comet PoE's unboxing video below.
