Zum Inhalt
Brume (GL-MV1000) Benutzerhandbuch
Produktübersicht
Brume (GL-MV1000) and Brume-W (GL-MV1000W) are powerful and stable networking products designed to do cutting-edge computing. With the Marvell high-performance chipset, the Brume and Brume-W can run state-of-the-art cryptography at impressive speeds for an excellent VPN routing experience. Pre-installed OpenWrt and supported Ubuntu, Brume and Brume-W allows in-depth developments for commercial IoT projects.
Brume-W (GL-MV1000W) is the special edition of Brume (GL-MV1000) that comes with an embedded Wi-Fi module, which delivers high-speed Wi-Fi performance on 2.4GHz Wi-Fi with up to 300Mbps Wi-Fi speed.
Technische Daten
GL-MV1000 specifications
Erste Einrichtung
All GL.iNet routers have a similar setup process. Click here to learn about the first time-setup.
INTERNET
Melden Sie sich im Web-Admin-Panel des Routers an und wechseln Sie im linken Menü zu INTERNET.
Auf dieser Seite können Sie je nach Modell Ihre Internetverbindungsart auswählen, z. B. Ethernet, Repeater, Tethering und Cellular.
For Brume (GL-MV1000), it supports three types of connection type: Ethernet, Tethering, and Cellular.
Ethernet
Connect your router to an active modem or an active network device via an Ethernet cable to access the Internet. This method usually provides the fastest and most reliable Internet connection.
Klicken Sie hier, um zu erfahren, wie Sie über ein Ethernet-Kabel eine Internetverbindung herstellen
Ethernet Connection
Tethering
Connect the router's USB port to a smartphone with active mobile data via a USB cable to access the Internet. This method enables multiple devices connected to the router to access the internet using the smartphone's mobile data.
Klicken Sie hier, um zu erfahren, wie Sie über USB-Tethering eine Internetverbindung herstellen
Tethering Connection
Cellular
Connect the router to the internet by plugging a cellular-enabled USB modem into the router's USB port. This method is useful for sharing internet from a USB modem to all connected devices.
Klicken Sie hier, um zu erfahren, wie Sie über ein USB-Modem eine Internetverbindung herstellen
Cellular Connection
Multi-WAN
Multi-WAN ist eine Netzwerkfunktion, mit der Sie Ihren Router gleichzeitig mit mehreren Internetverbindungen (z. B. Ethernet und Repeater) konfigurieren können. Wenn die Internetverbindung mit der höchsten Priorität ausfällt, wechselt der Router automatisch zu einer anderen Internetverbindung. Dies wird auch als Failover bezeichnet und sorgt für einen reibungslosen und unterbrechungsfreien Internetzugang.
Wechseln Sie zu Multi-WAN, um die Priorität jeder Internetverbindung festzulegen.
Alternativ können Sie den Multi-WAN-Modus von Failover auf Load Balance umstellen. Dadurch können Sie mehrere Netzwerkschnittstellen gleichzeitig nutzen, um die Gesamtbandbreite des Routers zu erhöhen.
CLIENTS
Clients sind Geräte, die mit dem Router verbunden sind. Sie können Clients blockieren oder ihre Netzwerkgeschwindigkeit begrenzen. Die Oberfläche ist über CLIENTS im Seitenmenü des Admin-Panels des Routers erreichbar.
Klicken Sie hier, um mehr über die Verwaltung Ihrer Geräte-Clients zu erfahren.
VPN
GL.iNet-Router sind mit OpenVPN und WireGuard® vorinstalliert und unterstützen mehr als 30 VPN-Dienste. Dadurch wird der gesamte Netzwerkverkehr im verbundenen Netzwerk automatisch verschlüsselt, einschließlich Gastgeräten und Client-Geräten, die selbst keine VPN-Verschlüsselung ausführen können. Unsere Router können außerdem als VPN-Server fungieren und den Verkehr von Client-Geräten an entfernten Standorten über einen VPN-Tunnel zum VPN-Server umleiten, bevor auf das öffentliche Internet zugegriffen wird.
VPN Dashboard
OpenVPN
Detaillierte Schritt-für-Schritt-Anleitungen finden Sie unter den folgenden Links:
WireGuard
Tor
APPLICATIONS
GL.iNet-Router bieten eine Vielzahl zusätzlicher Funktionen, die die Geräteverwaltung vereinfachen, das Interneterlebnis der Benutzer verbessern, Firmware-Updates automatisieren und vieles mehr.
Plug-ins
Lesen Sie das Tutorial Plug-ins.
Dynamic DNS
Lesen Sie das Tutorial Dynamic DNS.
GoodCloud
Lesen Sie das Tutorial GoodCloud.
Network Storage
Lesen Sie das Tutorial Network Storage.
AdGuard Home
Lesen Sie das Tutorial AdGuard Home.
Parental Control
Lesen Sie das Tutorial Parental Control.
ZeroTier
Lesen Sie das Tutorial ZeroTier.
Tailscale
Lesen Sie das Tutorial Tailscale.
NETWORK
Firewall
Die Router von GL.iNet bieten mehrere Firewall-Funktionen, um eine sichere Verbindung und vollständige Kontrolle für Benutzer zu gewährleisten. Damit können Firewall-Regeln wie Port Forwarding, Open Ports und DMZ konfiguriert werden.
Klicken Sie hier, um mehr über die Firewall der GL.iNet-Router zu erfahren
Multi-WAN
Lesen Sie das Tutorial Multi-WAN.
LAN
Lesen Sie das Tutorial LAN.
DNS
Lesen Sie das Tutorial DNS.
Network Mode
Lesen Sie das Tutorial Network Mode.
IPv6
Lesen Sie das Tutorial IPv6.
MAC Address
Die Seite Mac Address hieß früher Mac Clone und wurde seit v4.2 in Mac Address umbenannt.
Lesen Sie das Tutorial MAC Address.
Drop-in Gateway
Lesen Sie das Tutorial Drop-in Gateway.
IGMP Snooping
Lesen Sie das Tutorial IGMP Snooping.
SYSTEM
Overview
Lesen Sie das Tutorial System Overview.
Upgrade
GL.iNet stellt regelmäßig Updates für die Firmware unserer Router bereit, um die Leistung zu verbessern, Fehler zu beheben und Sicherheitslücken zu schließen.
Lesen Sie das Tutorial Upgrade.
Scheduled Tasks
Lesen Sie das Tutorial Scheduled Tasks.
Admin Password
Diese Funktion wurde seit v4.5 nach Security verschoben.
Lesen Sie das Tutorial Admin Password.
Time Zone
Lesen Sie das Tutorial Time Zone.
Toggle Button Settings
Lesen Sie das Tutorial Toggle Button Settings.
Log
Lesen Sie das Tutorial Log.
Security
Diese Funktion ist seit v4.5 verfügbar.
Lesen Sie das Tutorial Security.
Reset Firmware
Lesen Sie das Tutorial Reset Firmware.
Advanced Settings
Lesen Sie das Tutorial Advanced Settings.
