GL-S20 Benutzerhandbuch¶
Hardwareinformationen¶
GPIO-Liste¶
| ESP32-WROOM-32U GPIO Labeling | SIGNAL | FUNCTION |
| GPIO0 | GPIO0 | connected to ch340c pin DTR for the device to enter download mode |
| GPIO1 | BUTTON | button input, used for reset |
| GPIO2 | GPIO2 | used for control h2 reset io |
| GPIO3 | GPIO3 | used for control h2 boot io |
| GPIO4 | PHY_SPI_INT | interrupt GPIO number SPI Ethernet module |
| GPIO5 | PHY_RESET | PHY reset GPIO number of SPI Ethernet module |
| GPIO6 | NETWORK_LED | network led control (green) |
| GPIO7 | NETWORK_LED | network led control (red) |
| GPIO8 | UART1 RX | used for connect to h2 uart0 tx |
| GPIO9 | POWER_LED | power led control (green) |
| GPIO10 | PHY_SPI_CSN | SPI CS GPIO number for SPI Ethernet module |
| GPIO11 | PHY_SPI_MOSI | SPI MOSI GPIO number for SPI Ethernet module |
| GPIO12 | PHY_SPI_CK | SPI SCLK GPIO number for SPI Ethernet module |
| GPIO13 | PHY_SPI_MISO | SPI MISO GPIO number for SPI Ethernet module |
| GPIO14 | POWER_LED | power led control (red) |
| GPIO15 | NETWORK_LED | network led control (yellow) |
| GPIO16 | BUTTON | button input, used for iot function control |
| GPIO17 | IOT_LED | iot led control (green) |
| GPIO18 | IOT_LED | iot led control (red) |
| GPIO19 | IOT_LED | iot led control (yellow) |
| GPIO20 | POWER_LED | power led control (yellow) |
| GPIO21 | UART1 RTS | used for connect to h2 uart0 cts |
| GPIO35 | GPIO35 | NC |
| GPIO36 | GPIO36 | NC |
| GPIO37 | GPIO37 | NC |
| GPIO38 | GPIO38 | NC |
| GPIO39 | GPIO39 | NC |
| GPIO40 | PTA_REQUEST | used for PTA |
| GPIO41 | PTA_PRIORITY | used for PTA |
| GPIO42 | PTA_GRANT | used for PTA |
| GPIO43 | UART0 TX | used for debugging serial port output |
| GPIO44 | UART0 RX | used for debugging serial port output |
| GPIO45 | PTA_TX_LINE | used for PTA |
| GPIO46 | GPIO46 | NC |
| GPIO47 | UART1 CTS | used for connect to h2 uart0 rts |
| GPIO48 | UART1 TX | used for connect to h2 uart0 rx |
PCB-Pinbelegung¶
Erste Einrichtung¶
Please refer to GL-S20 on IoT docs.
Benutzerhandbuch¶
Please refer to User Manual on IoT docs.
Anleitung zur Firmware-Kompilierung¶
Please refer to Firmware Compilation Guide on IoT docs.
