Build up an Intranet with GL.iNet Routers¶
You can build up an intranet with GL.iNet for various purpose. For examples, connecting stage devices for outdoor shows, extend the distance of control for a drone, setup an office intranet...
Topology¶
An Office Intranet¶
You can connect your PC by a LAN cable and then connect the WiFi to your Laptop. Then they would be in the same intranet and you can use the Window Remote Desktop and remote them mutually.
More Examples¶
