How to connect a GL.iNet router to Starlink Dish?¶
If you need to connect a GL.iNet router to Starlink Dish, follow the steps below.
Topology
Connect the power of your Starlink router to the Starlink Dish.
Connect Starlink router's LAN port to GL.iNet router's WAN port.
Connect a device to the GL.iNet router's LAN port or WiFi, then configure the router for Internet access. First time setup
Note: If your GL.iNet router supports Network Acceleration, please go to the web Admin Panel -> NETWORK -> Network Acceleration and disable it.
Open Starlink App, go to Settings and enable the Bypass mode.
