How to remote access the web Admin Panel of GL.iNet router?¶
- Method 1: If your router's network has a public IP, please set up a WireGuard Server and use WireGuard to access the router's web Admin Panel. If you don't have a public IP, try other methods below.
- Method 2: Please bind your device to GoodCloud, then you can access the router's web Admin Panel remotely by logging into the GoodCloud website.
- Method 3: To use a SDWAN solution, we suggest AstroWarp.
- Method 4: To use a reverse proxy solution, we suggest AstroRelay.
