Advanced Settings
On the left side of the web Admin Panel, go to SYSTEM -> Advanced Settings.
You can modify advanced settings with LuCI, the default web user interface of OpenWrt.
advanced settings
As an open and independent project maintained by OpenWrt, LuCI is provided as-is. GL.iNet is not responsible for LuCI maintenance.
Click on Go To LuCI button, you will be re-directed to the LuCI login page.
luci login
Enter the login password, which is the same as the password of the web admin panel.
You will be logged into the LuCI page. This is an example of the LuCI page for GL-AX1800 (Flint).
luci logged in
