Display Management¶
Note: This feature is only available for GL-BE3600 (Slate 7) and GL-E5800 (Mudi 7).
On the left side of the web Admin Panel, go to SYSTEM -> Display Management.
This page lets you manage the touchscreen display and its related settings.
GL-BE3600¶
Function Management: Manage which functions are shown on the touchscreen.
Lock Screen: Customize the lock-screen settings, including the wake display and wallpaper.
Switch the wallper to Customize, and you can upload an image with a size not exceeding 5MB.
Brightness: Adjust the touchscreen brightness. Use the slider or enter a specific level (range from 1 to 10) to fit different lighting conditions.
- Auto Lock: Set the time delay for the screen to auto-lock when there is no activity. The range is 1 to 30 minutes.
- Screen Always On: Toggle this option to decide if the touchscreen stays on continuously or turns off after inactivity.
Enable Screen Passcode: Add an extra layer of security by enabling a passcode for the touchscreen (4-digit number only).
GL-E5800¶
- Wallpaper: Customize the wallpaper and wake display style.
- Brightness: Adjust the touchscreen brightness. Use the slider or enter a percentage to fit different lighting conditions.
- Personalised Signature: Add a custom text to the touchscreen to show your unique style or for quick identification.
- Auto Lock: Set the time delay for the screen to auto-lock when there is no activity. The range is 15 seconds to 5 minutes.
- Passcode: Set a passcode for the touchscreen for an extra layer of security.
