Firmware Upgrade
On the left side of web Admin Panel -> SYSTEM -> Upgrade
Online Upgrade
You can find the current firmware version here. If your router is connected to the Internet, it will check for the newer firmware version available for download.
upgrade
Preview Plan
Enable the switch to get latest unstable updates, patches, improvements, and enhancements as soon as they're available. Set it once and it stays on (you always have the option to turn it off later).
Check out the latest features at What's New?
Please contact us if you encounter any issues. support@glient.biz
Local Upgrade
Select a firmware file or drag and drop to upgrade. You can download the firmware from our download site.
local upgrade
After uploaded, it will verify the firmware.
Keep Setting: Current settings will be retained. User installed packages will be prompted to re-install after upgrade.
Click Install to upgrade.
Note: Please keep the power on during the upgrade.
local upgrade uploaded
Still have questions? Visit our Community Forum.
