MAC Address¶
This guide applies to firmware v4.5 and earlier.
The MAC Address page was previously titled MAC Clone and has been renamed to MAC Address since v4.2.
Since v4.6, the MAC address settings for Ethernet and Repeater interfaces have been moved to the Ethernet Port and Repeater respectively.
On the left side of the web Admin Panel, go to NETWORK -> MAC Address.
You can find the router's default MAC address, clone a client's MAC address, enter a MAC address manually, or generate a random MAC address.
If the device supports setting multiple Ethernet ports to be used as WAN ports, you can set the MAC address for each port separately. Note that the MAC address setting is only valid when the Ethernet port is used as a WAN port.
The factory default MAC address.
Clone a client's MAC address.
Note: Many new devices now use a different random MAC address to connect to different Wi-Fi, so the MAC address shown here may not be the actual MAC address of the user's device. The randomized MAC may also be called a Private Wi-Fi Address or a random hardware address on different devices.
Manual input or generate a random MAC address.
Usage Scenarios¶
When you connect to a public hotspot, use a random MAC address if you do not want the hotspot to know your real MAC address or to limit your access to the Internet based on it. Please read this guide Connect to a Hotspot with a Captive Portal.
