Port Management
Port Management is available since V4.7.
On the left side of web Admin Panel -> NETWORK -> Port Management.
It shows all Ethernet ports on the router.
Click on WAN, it displays the network port status, MAC mode & MAC address, as well as the negotiated network port rate of the WAN port.
wan port management
  • WAN/LAN: The current status of physical WAN port. You can use it as a LAN port to suit your needs.
  • MAC Mode: The MAC mode of WAN port is factory by default. You can switch it to Clone Mode or Random Mode.
  • Mac Address: The MAC address of the WAN interface.
  • Negotiated Network Port Rate: The current negotiated speed of WAN interface.
Click on LAN, it displays the negotiated network port rate of the LAN port.
lan port management
Some models such as GL-MT6000 and GL-XE3000, support switching a LAN port to be WAN port, as shown below. Thus a Dual-Ethernet WAN scenario can be achieved.
wan port management
