Toggle Button Settings¶
The Toggle Button Settings allow you to assign specific functions to the physical toggle switch (also known as a mode switch on some models) on your router for quick access and control, providing convenient shortcuts for common operations.
You can customize the switch behavior in the web Admin Panel.
Supported Models¶
Supported Models
- GL-BE10000 (Slate 7 Pro)
- GL-MG1300 (Mango 2)
- GL-MT3600BE (Beryl 7)
- GL-BE3600 (Slate 7)
- GL-MT3000 (Beryl AX)
- GL-AXT1800 (Slate AX)
- GL-MT1300 (Beryl)
- GL-SFT1200 (Opal)
- GL-A1300 (Slate Plus)
- GL-MT300N-V2 (Mango)
- GL-AR300M Series (Shadow)
- GL-S200
- GL-E750V2 (Mudi V2)
- GL-AR750S (Slate)
- GL-AR750 (Creta)
Unsupported Models
- GL-MT6000 (Fortify)
- GL-BE14000 (Flint 4)
- GL-E5800 (Mudi 7)
- GL-MT5000 (Brume 3)
- GL-BE6500 (Flint 3e)
- GL-BE9300 (Flint 3)
- GL-X2000 (Spitz Plus)
- GL-B3000 (Marble)
- GL-MT6000 (Flint 2)
- GL-X3000 (Spitz AX)
- GL-XE3000 (Puli AX)
- GL-AX1800 (Flint)
- GL-MT2500/GL-MT2500A (Brume 2)
- GL-X750/GL-X750V2 (Spitz)
- GL-XE300 (Puli)
- GL-B1300 (Convexa-B)
- GL-AP1300 (Cirrus)
- GL-X300B (Collie)
Setup¶
On the left side of the web Admin Panel, go to SYSTEM -> Toggle Button Settings.
Prior to firmware v4.8, there are five options, allowing users to customize the toggle button's functionality.
- No Function
- AdGuard Home
- OpenVPN Client
- Tor
- WireGuard Client
Since firmware v4.8, more options have been introduced: Repeater, Wi‑Fi, and LED. Users can customize the toggle buttons according to their needs.
- No Function
- Repeater
- Wi-Fi (Main/Guest Wi-Fi)
- VPN
- Tor
- AdGuard Home
- LED
When applying settings, you can decide whether or not to immediately enable/disable your selected feature based on the toggle switch's on/off(left/right) position.
Note: After a device reboot, the system will automatically apply the feature state according to the toggle switch position.
For example, if you configure the WireGuard Client to be controlled by the toggle switch: When the switch is LEFT (ON), the WireGuard Client starts automatically. When the switch is RIGHT (OFF), the WireGuard Client remains disabled.
