UI Languages¶
This feature has been added since firmware v4.6.
You can click the language button in the upper right corner to switch or add UI languages.
To add additional UI languages or update UI text, click Add Languages.
In the pop-up window, select your desired language and click Update. The router will automatically pull the latest language pack from our repository. Uninstalled language packs will be removed (except English).
If you want to automatically get the latest language pack to fix potential text issues, toggle on Enable Auto Update and set the update time. The router will then automatically download the latest language pack at the specified time.
