Set Up WireGuard Client on GL.iNet Routers
The content on this page is based on firmware v4.6 and earlier. If your device is running a different firmware version, use the selector below to switch to the corresponding guide.
WireGuard® is an extremely simple yet fast and modern VPN that utilizes state-of-the-art cryptography. It aims to be faster, simpler, leaner, and more useful than IPsec, while avoiding the massive headache. It intends to be considerably more performant than OpenVPN.
If you have already bought WireGuard service from a provider, but you don't know how to get the configuration files, please refer to get configuration files from WireGuard service providers or ask its support.
You can set up WireGuard Client via the web Admin Panel or mobile app.
  • The mobile app has integrated with several WireGuard service providers, such as AzireVPN, Mullvad, OVPN, StrongVPN, and PIA VPN.
  • The web Admin Panel supports fewer WireGuard service providers (e.g., AzireVPN and Mullvad), but provides more intuitive and detailed pages.
Below are the steps to set up via the web Admin Panel.
Log in to the web Admin Panel and navigate to VPN -> WireGuard Client.
If you have AzireVPN or Mullvad membership, you can log in with their credentials directly. Alternatively, click Add Manually to upload the WireGuard profiles manually.
wireguard client no initialized
Set Up AzireVPN
AzireVPN is privacy-minded VPN service providing secure, modern and robust tunnels such as WireGuard.
azirevpn
  1. Input Username and Password, then click Save Credentials & Get Servers. It will generate configuration files for each servers.
    azirevpn profiles
  2. Go to VPN Dashboard to enable the connection.
    vpn dashboard azirevpn
    Once connected, you should see your user IP address and the number of Bytes send/received.
    vpn dashboard azirevpn connected
  3. Update servers
    AzireVPN may maintain or shutdown some servers, it will make the connection failed, you can Update Servers to get the latest available servers.
    azirevpn update servers
  4. Edit credential
    Click the cog icon to edit the credential.
    azirevpn edit credential
Set Up Mullvad
Mullvad is a VPN service that helps keep your online activity, identity, and location private.
Firmware 4.x has integrated Mullvad WireGuard service.
mullvad vpn
  1. Input Account, then click Save Credentials & Get Servers.
    Mullvad account number is a 16-digit decimal in the "1000 0000 0000 0000" to "9999 9999 9999 9999" range.
    It will pop up a dialog to select a location.
    mullvad vpn
    Then it will generate the configuration files of the selected location server.
    The Public Key is the WireGuard public key to send to Mullvad server, you can have up to five keys at the same time, you can manage WireGuard keys on Mullvad's page.
    mullvad vpn
    mullvad vpn
    vpn dashboard mullvad connected
  3. Update servers
    Mullvad may maintain or shutdown some servers, it will make the connection failed, you can Update Servers to get the latest available servers.
    mullvad vpn
  4. Edit credential
    mullvad vpn
  5. Delete account information
    If you click Delete, it will delete the account credential, private key, public key and configuration files in the router.
    mullvad vpn
  6. Delete
    Allow deleting all configuration files with one click and provide a prompt to also delete private key and public key.
    mullvad vpn
Set up WireGuard Client
As of firmware 4.0, it brings grouping to manage WireGuard profiles.
  1. Click Add Manually.
    add manually
  2. It will create a group.
    add a new group
  3. Give the group a descriptive name, e.g. azirevpn. Then you can choose to upload configuration files or manually add configuration.
    set the new group name
    1. Upload configuration files
      Upload your WireGuard configuration file, click Apply.
      upload profile
      after upload profile
    2. Manually Add Configuration, it is for if you want to paste the WireGuard configuration or fill in each item.
      add wireguard by text
      Give a descriptive name and paste the configuration, click Apply to continue.
      Or you can add configuration by fill in each item, click Item Mode.
      add wireguard by item mode
  4. Click the three dots icon to start / edit /delete the profile.
    start the profile
  5. Check the connection status by go to VPN Dashboard page.
    vpn dashboard page
