Can I use Multi-WAN wired input if my GL router doesn't have two WAN ports?
Yes, you can. Our router supports most common Ethernet to USB-A adapters. Simply plug the Ethernet to USB-A adapter into the USB port on the router and connect the other end to your ISP router.
Topology
Topology
Install USB Driver
Then, navigate to Application, Plug-ins to install the USB network driver for your adapter.
plugins
For instance, if you’re using a Realtek adapter, please select the kmod-usb-net-rtl8152 driver.
Connect by Tethering
Once the installation is complete, the USB connection will be detected, allowing you to connect to your ISP router.
suceeded
detected
tether
