Get Module Logs¶
Some GL.iNet routers come with built-in 3G/4G/5G modules. When the network connection is unstable, it may be necessary to export the module's log for analysis.
Here are the steps to export the cellular module's log.
1. Connect your computer to the router¶
Connect a laptop to the router's Wi-Fi (find the SSID and password on the device bottom label), or connect the ethernet port of your computer to the router's LAN port via an ethernet cable.
2. SSH log in to your router¶
Please refer to this link.
3. Get module logs¶
For GL-XE300/GL-X750/GL-X300B¶
Use the following commands to get qlog from GL.iNet server, and confirm the qlog file SHA256 is right.
cd /usr/bin/ && wget https://fw.gl-inet.com/tools/quectel_tool/qlog-ar9531-sha256-75fe8bchmod 775 qlog-ar9531-sha256-75fe8b && sha256sum qlog-ar9531-sha256-75fe8b
Insert a USB flash disk and use the df command to get the mount path, remember the path
My USB flash disk mount path is
/tmp/mountd/disk1_part1
Use the following command to open module debug mode
gl_modem AT AT+QCFG=\"dbgctl\",0 -
Use the following command to start qlog
qlog-ar9531-sha256-75fe8b -s /tmp/mountd/disk1_part1/qlogs_$(date +%Y%m%d%H%M) &The
/tmp/mountd/disk1_part1is my USB flash disk, you must change the path to your path -
Use the following command to reboot model.
gl_modem AT AT+CFUN=0; sleep 1; gl_modem AT AT+CFUN=1 -
Wait 1~3 minutes, use the following command to stop qlog
ps | grep qlog | grep -v grep | awk '{print $1}' | xargs kill -9
You will find a directory in the USB flash disk, there are some files, these files are qlog get data and need use Quectel tool to decode, so please send these files to GL.iNet or Quectel technical support.
For GL-X3000/GL-XE3000¶
Get the qlog from GL.iNet server and confirm the qlog file sha256 is right
cd /etc/ && wget https://fw.gl-inet.com/tools/quectel_tool/default_v15.cfgcd /usr/bin/ && wget https://fw.gl-inet.com/tools/quectel_tool/qlog-mtk7981a-sha256-78dda4chmod 775 qlog-mtk7981a-sha256-78dda4 && sha256sum qlog-mtk7981a-sha256-78dda4 && sha256sum /etc/default_v15.cfg
qlog-mtk7981a-sha256-78dda4 -f /etc/default_v15.cfg -s /tmp/mountd/disk1_part1/qlogs_$(date +%Y%m%d%H%M) & -
gl_modem -B 0001:01:00.0 SAT sp AT+CFUN=0; sleep 1; gl_modem -B 0001:01:00.0 SAT sp AT+CFUN=1 -
After captured packets with qlog, use the following command to stop qlog
