How to connect to the dedicated IP by NordVPN on GL.iNet routers?¶
This article introduces the steps to set up the dedicated IP by NordVPN.
Here we take GL-AXT1800 as an example.
Log in to your Nord Account and check the dedicated IP info. As the following picture shows, the assigned IP is 193.32.211.142 and the server info is United Kingdom #1625.
Go to this link: https://nordvpn.com/ovpn/ and find the config file of United Kingdom #1625. Download the UDP or TCP config file as you want.
Back to the Nord Account page, go to Manual setup and click on Set up NordVPN Manually to get the service credentials.
Log in to the web Admin Panel of your router, go to VPN > OpenVPN Client, create a new group to upload the config file you downloaded in step 2. Then type in the service credentials you got in step 3.
Go to VPN Dashboard, select the config file and click on Apply to connect to it.
When it is connected, you can check your public IP here: https://whatismyipaddress.com/ and confirm if it matches with the dedicated IP by NordVPN.
