How to set up a guest Wi-Fi network on GL.iNet routers¶
This tutorial will show you how to set up a guest Wi-Fi network on GL.iNet routers.
A guest Wi-Fi network is a separate network on a router for devices you want to isolate from your main devices. These include guest devices and your smart home devices. By creating a guest network, you can prevent unauthorized access to and potential attacks on your primary network, enhancing your network security.
There are two methods you can use to set up a guest Wi-Fi network on your GL.iNet router: via the router admin panel or the GL.iNet mobile app.
Set up a guest network via the admin panel¶
1. Enable the guest Wi-Fi network¶
- In a web browser, enter
192.168.8.1. - Enter your password, then click Login.
- In the left sidebar, click Wireless.
- In the section for your 5GHz or 2.4GHz Wi-Fi network, click the Guest Wi-Fi tab.
- Next to Enable Wi-Fi, toggle the switch to on.
2. Set a new guest Wi-Fi network password¶
To ensure your security, you are advised to set a new password for your guest Wi-Fi network. Follow these steps:
- Click Modify.
- Next to Wi-Fi Password, enter a new password. (You can also enter a new network name next to Wi-Fi Name.)
- After that, click Apply.
You have now set up a guest Wi-Fi network. To connect your devices to it, locate the guest network name on the list of available networks and enter the password.
Set up a guest network via the GL.iNet mobile app¶
Note: Before you start, install and set up the GL.iNet mobile app on your device.
- On the main app screen, tap the Network tab > Wireless.
- Locate Guest Network.
- For the network where you want to set up a guest Wi-Fi network, toggle the switch to on.
- Tap the SSID option for the network where you set up a guest Wi-Fi network.
- Next to Password, enter a new password. (You can also enter a new network name in the SSID field.)
- Tap Done.
Related Articles:
