How to use the SIMPoYo eSIM Physical Card with Android devices¶
This guide provides step-by-step instructions for setting up and activating the eSIM Physical Card purchased from the GL.iNet online store. The eSIM Physical Card is compatible with most Android devices, offering effortless internet connectivity and seamless performance.
Features¶
The highlights of eSIM physical cards are as follows:
- Supports 4G and 5G networks for reliable and fast connections.
- Manage your eSIM profiles effortlessly by adding, removing, or enabling them.
- Select and purchase your preferred data packages from most eSIM stores worldwide at any time.
- Works with eSIM profiles from most global eSIM stores.
- Purchase eSIM profiles online without providing personal information, reducing the risk of privacy breaches.
- Comes with a seed profile that includes 1GB of free data for the U.S. and Europe, plus 100MB of Global Data, valid for 1 year from the activation date.
- Compatible with most Android devices.
Set Up the eSIM Physical Card on Android Devices¶
If you’re using the eSIM Physical Card for the first time, watch this video or follow the steps below.
1. Connect to the Internet¶
Ensure that your Android device is connected to the internet. You can either connect via Wi-Fi connection or use the preloaded data included with the eSIM Physical card.
2. Insert the eSIM Physical Card¶
Insert the eSIM Physical Card into your Android device's SIM card slot.
3. Download the EIOTCLUB App¶
Download the EIOTCLUB app via this link: https://sim.eiotclub.com/eshop/download.
Note
Ensure your device runs Android 9 or above. iPhone does not support this eSIM physical card.
4. Create a New Account¶
Sign up for a new account in the EIOTCLUB app.
5. Add SIM Card¶
Automatic Card Detection: Once the eSIM Physical Card is inserted and the EIOTCLUB app is open, it will be automatically detected. When prompted, simply tap OK to continue.
Manual Card Addition: Alternatively, click the Add button to manually scan or enter your ICCID numbers. Then, tap Next to proceed. When a prompt appears, tap OK to confirm.
6. Check and Manage Profiles¶
After completing the setup, the app will show these sections:
a. eSIM Card Slot 1: The name of your eSIM card.
b. eSIM Profiles: A list of eSIM profiles successfully added to your eSIM card.
c. Remote: A management option for adding, removing, or updating your eSIM profiles.
Add or Purchase a New eSIM Profile¶
After setting up the eSIM on your Android device, you’ll have access to a preloaded data package from GL.iNet:
- 100MB Global Data
- 1GB Data for Europe and the U.S.
These packages are ideal for downloading a new eSIM profile if you arrive in a location without internet access.
To add an eSIM profile, you can directly click the Add button from the SIM Card Section of the app.
Method 1: Add a Purchased eSIM Profile¶
If you’ve already purchased an eSIM profile from your preferred eSIM store, follow these steps to add it:
1. Tap the Add Button¶
Open the app and tap the Add button to start adding your eSIM profile.
2. Select a QR Code Scanning Option¶
a. Scan the QR Code: Use your device’s camera to scan the QR code provided by the eSIM store.
b. Import from Album: Upload the QR code image from your photo gallery.
c. Enter Activation Code: Manually input the eSIM profile URL into the Activation Code field.
3. Download and Install¶
After selecting the appropriate method, tap Download & Install to complete the process.
Method 2: Purchase and Add an eSIM Profile via eSIM Shop¶
You can purchase and add a profile directly from the eSIM Shop within the app:
1. Choose Your Data Package¶
Select the data package that suits your needs—Local, Regional, or Global.
2. Complete Your Purchase¶
Follow the app’s guided steps to finalize your purchase.
3. Locate Your Purchased Profile¶
After completing your purchase, the new eSIM profile will appear in the SIM Card Section of the app.
4. Add the eSIM to Your Profile List¶
Tap the Add button next to the purchased eSIM profile to add it.
5. Download the Profile¶
Tap the Download button to begin the installation process.
6. Install the Profile¶
Tap Download & Install to finalize the installation.
7. Successfully Added¶
Your new eSIM profile will now appear in the eSIM profile list.
Enable or Switch Profiles¶
1. Access Your Profiles¶
Tap Remote to view all the eSIM profiles you’ve added.
2. Enable Your Profile¶
Find the desired profile and tap the Toggle button to enable it.
Delete an eSIM Profile¶
1. Turn Off the eSIM Profile:¶
- Go to your eSIM settings and ensure the profile is turned off.
- Tap on the eSIM profile name you want to delete.
2. Access eSIM Details¶
Navigate to the eSIM details page and tap Delete eSIM.
3. Confirm Delete eSIM Profile¶
Confirm the action by tapping the Submit button to delete the eSIM profile.
Delete an eSIM Card Slot¶
1. Open SIM Card Settings¶
Click on the eSIM name to access the SIM Card Settings.
2. Tap the Delete Button¶
Tap the Delete eSIM Card SLOT button.
3. Confirm Deletion¶
Tap Submit button to delete the eSIM slot.
