GL.iNet Router Docs 4
Comet (GL-RM1) User Guide
English
Japanese
Initializing search
gl-inet/docs4.x
Home
User Guide
Tutorials
Interface Guide
Video Library
Community
gl-inet/docs4.x
Home
User Guide
User Guide
GL-MT3600BE (Beryl 7)
GL-E5800 (Mudi 7)
GL-MT5000 (Brume 3)
GL-BE9300 (Flint 3)
GL-BE6500 (Flint 3e)
GL-BE3600 (Slate 7)
GL-X2000 (Spitz Plus)
GL-B3000 (Marble)
GL-MT6000 (Flint 2)
GL-XE3000 (Puli AX)
GL-X3000 (Spitz AX)
GL-MT3000 (Beryl AX)
GL-AXT1800 (Slate AX)
GL-A1300 (Slate Plus)
GL-AX1800 (Flint)
GL-MT2500/GL-MT2500A (Brume 2)
GL-SFT1200 (Opal)
GL-MT300N-V2 (Mango)
GL-AR300M (Shadow)
GL-M2
GL-S200
GL-S20
GL-S10
GL-MT1300 (Beryl)
GL-AP1300 (Cirrus)
GL-E750/GL-E750V2 (Mudi/Mudi V2)
GL-X750 (Spitz)
GL-XE300 (Puli)
GL-X300B (Collie)
GL-AR750S (Slate)
GL-AR750 (Creta)
GL-B1300 (Convexa-B)
GL-S1300 (Convexa-S)
GL-MV1000 (Brume)
Internet
Internet
First time setup
Warning from your browser
Connect to public hotspot with Captive Portal
Connect Ethernet-only device to Wi-Fi
Problem Notification
Problem Notification for GL-MT2500/GL-X3000/GL-XE3000
Problem Notification and Solutions for GL-X3000/GL-X2000 Failure to Work with EE SIM Cards
Troubleshooting
Troubleshooting
Cannot access web Admin Panel
Cannot Scan Android 5G Hotspot
Cannot Scan iPhone 5G Hotspot
iPhone tethering failed
Cellular Network Troubleshooting Guide
Replacing the old router with GL.iNet router but has no internet
USB modem is not working
Repair network or reset
What should I do if my router is bricked
MacOS cannot write to a Samba share
WireGuard server is not working properly
Stuck on "Installing" during firmware update
Stuck on "Reverting" during firmware reset
Stuck on "Rebooting" during firmware reboot
How to resolve a subnet conflict
Why do I get a message from DDNS test
Why is my VPN speed slower than expected
What is the device capacity of my router
What is the wireless coverage of my router
Upgrade Uboot version
VPN
VPN
How to set up OpenVPN
How to set up WireGuard
How to Block Non-VPN Traffic
VPN Kill Switch
TCP or UDP
Do I have to configure Ethernet WAN when using VPN
Upgrade
Upgrade
Download firmware
Manually upgrade or downgrade
Other
Other
LED Indication
GL.iNet Mobile App
Add Brume 2 into mobile App
Change WAN to LAN
Access GL.iNet and Adguard Home via HTTPS
Connect to Starlink Dish
Remote Web Admin
Remote SSH to router
Public IP checking
Make WiFi Calling work on Opal
Find all MAC addresses
Find device info
What is LuCI
Tutorials
Tutorials
VPN
VPN
Set up OpenVPN client
Set up OpenVPN server
Build your own WireGuard home server
Set up VPN Obfuscation
Connect to the dedicated IP by NordVPN
Connect to the dedicated IP by Surfshark
Set up OpenVPN server via Astrorelay
Set up WireGuard server via Astrorelay
Access OpenVPN Client LAN from Server
Access WireGuard Client LAN from Server
Access OpenVPN Server LAN from Client via domain name
Access WireGuard Server LAN from Client via domain name
Enable OpenVPN TAP-S2S
Enable VPN Cascading
Use WireGuard to secure RDP from outside network
Get config files from WireGuard service providers
Reserve fixed IP for OpenVPN client
Allow access to WAN when VPN client is enabled
Route VPN Client DNS to Server Upstream DNS
Cellular
Cellular
SMS Forwarding
Get Module Logs
Upgrade Quectel Module
Check carrier aggregation status
Set up Spitz AX for RV
Install or change external antennas for Spitz AX or Puli AX
eSIM
eSIM
Use eSIM Physical Card with GL.iNet routers
Use eSIM Physical Card with Android devices
How to use SIMPoYo uFi
GoodCloud
GoodCloud
Site to Site
Access the LuCI via GoodCloud
Network
Network
Connect to EAP network
Set up a guest network
Set up drop-in gateway
Set up port forwarding on primary router
Configure dual wired WAN access
Others
Others
Block client devices
Manually configure static IP on client devices
Check if you have a public IP
Upgrade or downgrade your router
SSH log in to the Router
Use WinSCP to access share files
Use WinSCP to modify files
Activate or top up T-Mobile SIM cards
Change the NAT type on Gaming
Retrieve the mobile App log
Configure Domain and IP Filtering rules for VPN
Technical Support via GoodCloud
Interface Guide
Interface Guide
Internet Connection
Internet Connection
Internet
Ethernet
Repeater
Tethering
Cellular
SMS
Dual-Ethernet WAN
Wireless
Wireless
Wireless
Clients
Clients
Clients
Cloud Services
Cloud Services
GoodCloud
AstroWarp
VPN
VPN
VPN Dashboard
OpenVPN Client
OpenVPN Server
WireGuard Client
WireGuard Server
Tor
Applications
Applications
Plug-ins
Dynamic DNS
Network Storage
AdGuard Home
Parental Control
ZeroTier
Tailscale
eSIM Management
Network
Network
Firewall
Port Forwarding
Multi-WAN
LAN
Guest Network
DNS
Ethernet Port
Network Mode
IPv6
MAC Address
Drop-in Gateway
IGMP Snooping
Hardware Acceleration
Network Acceleration
NAT Settings
Flow Control
Flow Control
DPI License
Data Statistics
Content Filter
QoS
SQM
System
System
Overview
Upgrade
Scheduled Tasks
Admin Password
Display Management
USB & Power
Time Zone
Toggle Button Settings
Log
Security
Reset Firmware
Advanced Settings
Language
Help
Video Library
Video Library
Meet Our New Products
Unboxing & First Time Setup
Tutorials
Community
Community
Please visit
GL.iNet KVM Docs
for more instructions.
Back to top
