Puli (GL-XE300) User Guide¶
Product overview¶
Puli (GL-XE300) is a portable 4G smart router that is perfect for home, travel, business and IoT solution. With its OpenWrt supported feature and large storage compatibility, it is designed for you to develop DIY IoT project. It also comes with a rechargeable battery, enabling portable use in various environments.
Package contents¶
Please note that the adapter within the package depends on your shipping country.
The package includes:
- 1 x User manual
- 1 x Puli (GL-XE300)
- 1 x Ethernet cable
- 1 x Thank you card
- 1 x Warranty card
- 1 x Power adapter (Selected plug type)
Check out Puli's unboxing video.
Specifications¶
First-time setup¶
All GL.iNet routers have a similar setup process. Click here to learn about the first-time setup.
INTERNET¶
Log in to the router's web Admin Panel, and navigate to INTERNET from the left-side menu.
This page allows you to select your internet connection type, such as Ethernet, Repeater, Tethering, and Cellular.
Ethernet¶
Connect your router to an active modem or an active network device via an Ethernet cable to access the Internet. This method usually provides the fastest and most reliable Internet connection.
Click here to learn how to connect to the internet via an ethernet cable
Repeater¶
Set up your router as a repeater to extend the Wi-Fi coverage of an existing Wi-Fi network. As a repeater, it receives and retransmits wireless signals within its range, thereby extending its coverage. This method is useful when a single router cannot cover the entire usage area.
Click here to learn how to connect to the internet via an existing Wi-Fi
Tethering¶
Connect the router's USB port to a smartphone with active mobile data via a USB cable to access the Internet. This method enables multiple devices connected to the router to access the internet using the smartphone's mobile data.
Click here to learn how to connect to the internet via usb tethering
Cellular¶
Insert a SIM card into the SIM card slot to connect it to the internet. This method is useful for sharing internet access from a single SIM card to all connected devices.
Click here to learn how to connect to the internet via cellular or usb modem
Multi-WAN¶
Multi-WAN is a networking feature that allows you to set up your router with multiple internet connections (e.g., Ethernet, Repeater) at the same time. If the top-priority internet connection fails, the router will automatically switch to another internet connection. This is also called Failover, ensuring smooth and uninterrupted internet access.
Go to Multi-WAN to set the priority of each Internet connection.
Alternatively, you can switch the Multi-WAN mode from Failover to Load Balance, which enables you to use multiple network interfaces at the same time to increase the total bandwidth of the router.
WIRELESS¶
The wireless settings lets users manage network security of the primary Wi-Fi and the Guest Wi-Fi, it is accessible by going to WIRELESS on the side menu.
Click here to learn more about the wireless configuration
CLIENTS¶
Clients are devices connected to the router, you can block clients or limit its network speed. The interface is accessible by clicking CLIENTS in the side menu of the router's Admin Panel.
Click here to learn more about managing your device clients.
VPN¶
GL.iNet routers are pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including guest devices and client devices that are not capable of running VPN encryption. Our routers can also act as VPN servers, redirecting traffic from client devices in remote locations to the VPN server via a VPN tunnel before accessing the public internet.
VPN Dashboard¶
OpenVPN¶
Please refer to the following links for a step to step setup guide:
WireGuard¶
Tor¶
APPLICATIONS¶
GL.iNet routers include a wide range of add-on features that simplifies device management, improves user's internet experience, automates firmware update, and more.
Plug-ins¶
Please visit the Plug-ins tutorial.
Dynamic DNS¶
Please visit the Dynamic DNS tutorial.
GoodCloud¶
Please visit the GoodCloud tutorial.
Network Storage¶
Please visit the Network Storage tutorial.
AdGuard Home¶
Please visit the AdGuard Home tutorial.
Parental Control¶
Please visit the Parental Control tutorial.
ZeroTier¶
Please visit the ZeroTier tutorial.
NETWORK¶
Firewall¶
GL.iNet's routers include multiple firewall features to ensure a secure connection and complete oversight by users. It lets users configure firewall rules including Port Forwarding, Open Ports, and DMZ.
Click here to learn more about GL.iNet routers' firewall
Multi-WAN¶
Please visit the Multi-WAN tutorial.
LAN¶
Please visit the LAN tutorial.
DNS¶
Please visit the DNS tutorial.
Network Mode¶
Please visit the Network Mode tutorial.
IPv6¶
Please visit the IPv6 tutorial.
MAC Address¶
The Mac Address page was previously called Mac Clone and has been changed to Mac Address since v4.2.
Please visit the MAC Address tutorial.
Drop-in Gateway¶
Please visit the Drop-in Gateway tutorial.
IGMP Snooping¶
Please visit the IGMP Snooping tutorial.
SYSTEM¶
Overview¶
Please visit the System Overview tutorial.
Upgrade¶
GL.iNet provides regular updates on our routers' firmware to improve performance, resolving bugs and fix vulnerabilities.
Please visit the Upgrade tutorial.
Scheduled Tasks¶
Please visit the Scheduled Tasks tutorial.
Admin Password¶
This feature has been moved to Security since v4.5.
Please visit the Admin Password tutorial.
Time Zone¶
Please visit the Time Zone tutorial.
Log¶
Please visit the Log tutorial.
Security¶
This feature is available since v4.5.
Please visit the Security tutorial.
Reset Firmware¶
Please visit the Reset Firmware tutorial.
Advanced Settings¶
Please visit the Advanced Settings tutorial.
