How to Fix Mouse Cursor Overlay Issue on macOS?
When using GL-RM1, you may get the issue that the mouse cursor of the controlling device can't be superimposed on the controlled macOS device.
mouse cursor cannot be superimposed
It's related to the display resolution. The macOS resolution is different from that of GLKVM.
Please go to the Settings -> Displays -> Optimize for.
settings
Change it to GLKVM.
select glkvm
Choose the Resolution you prefer, and you’ll find the mouse cursor is superimposed. Then you can enjoy using it.
resolution
