Set up WireGuard Server on GL.iNet router¶
WireGuard® is an extremely simple yet fast and modern VPN that utilizes state-of-the-art cryptography. It aims to be faster, simpler, leaner, and more useful than IPSec, while avoiding the massive headache. It intends to be considerably more performant than OpenVPN.
GL.iNet routers have pre-installed WireGuard Server and Client. You can set a GL.iNet router as an WireGuard server or client and establish VPN connection.
Make sure you have a public IP address¶
Please click here to check if you Internet Service Provider assigns you a public IP address.
If not, your router cannot be set as a WireGuard Server.
Alternative methods:
If you have a primary router, log in to it and check if it gets a public IP from your ISP.
Ask your ISP for a public IP address. This may incur an extra fee.
If the above two methods don't work (e.g., if your network is behind CGNAT), you may try our SD-WAN solution AstroWarp.
Confirm if Port Forwarding is required¶
If GL.iNet router is the primary router in your network, no port forwarding is required. Please move to the next step.
If a primary router is already in use and the GL.iNet router is configured as a secondary router, you will need to configure port forwarding on the primary router. Refer to here for instructions, and reach out to the primary router’s technical support if necessary.
If a primary router is already in use and the GL.iNet router is several levels below the primary router, configure port forwarding on each intermediate level.
Initialize WireGuard Server¶
Log in to the web Admin Panel, and navigate to VPN -> WireGuard Server. Click Initialize WireGuard Server.
Start the WireGuard Server¶
You can simply use the default parameters of IP Address and Local Port, or set your own value. Then click Start to start your own WireGuard server.
Allow Access Local Network: Enable this will allow every client that connect to this WireGuard Server be able to access your LAN. Please use with caution.
Add a new client¶
You have to add a new user and apply the configurations when you are connecting to this WireGuard Server.
Click Management tab and then Add a New User.
Specify the Name of the new client and then click Add.
Get the configuration details for your client¶
You can now check the list of the clients you added. Please click Configurations to find the configuration details you need to use when you are setting up WireGuard client.
We provide QR code and Plain Text, you can use a Text Editor software to save the Plain Text to .conf file.
Enable DDNS (Optional)¶
Some Internet Service Providers may assign you a dynamic IP address, which means it changes from time to time. In this case, please enable the DDNS, then edit the configuration to replace the public IP address with your DDNS url.
- Copy the content of the configuration to a text editor(e.g. Atom, Sublime).
Edit the configuration to replace DDNS url with your public IP address.
After replaced.
Copy the revised content to generate a QRCode, or save it as
.conffile.
The WireGuard connection may down a while when the public IP address changes, after the DDNS url update to the new public IP address, the conneciton will resume. The DDNS is updated every 10 minutes. If the connection doesn't resume, please make sure the DDNS url is point to tne new public IP address, then turn off the WireGuard connection and turn on again.
Check if WireGuard Server is working properly¶
Connect another device (e.g., another GL.iNet router, a laptop, or a smartphone) to a different network, then import the previously exported WireGuard configuration file to it. Start the VPN connection and check if it connects to your WireGuard Server successfully, and if its IP address is the WireGuard Server's IP.
The simplest method is to use a smartphone with the official WireGuard App installed. First, disable the smartphone's Wi-Fi and connect exclusively to the internet via cellular data (4G/5G). Then open the WireGuard app, import the configuration file, and initiate the connection. Check if the smartphone can access the internet and if its IP address matches the WireGuard Server's IP.
If the connection fails, there are several common reasons:
- The Internet Service Provider doesn't assign you a public IP address. Please check here.
- You may need to set up port forwarding. Please check here.
- The port used for the WireGuard Server is blocked by your Internet Service Provider. Change to another port, or contact the Internet Service Provider for further assistance.
- Some countries/regions may block the VPN connection.
WireGuard Client App¶
- Please refer to WireGuard Official Website.
Related Articles
