Access GL.iNet router and Adguard Home via HTTPS¶
If you want to use HTTPS to access GL.iNet router and Adguard Home, follow the steps below.
1. Update certificate and key in GL.iNet router¶
First, please apply for an SSL cert or use a self-signed SSL cert.
Then SSH into your GL.iNet router or use WinSCP to upload the updated certificate and key to your GL.iNet router. The paths are:
/etc/nginx/nginx.cer
/etc/nginx/nginx.key
2. Enable AdGuard Home¶
Log in to the GL.inet web Admin Panel -> APPLICATIONS -> AdGuard Home, enable AdGuard Home.
Then click the Settings Page at the top of this page, you will be re-directed to Adguard Home Settings Page.
3. Edit Encryption settings¶
In the Adguard Home Settings Page, navigate to the Settings -> Encryption settings.
Check the Enable Encryption box on the top left, and input 3001 at the HTTPS port.
Add the paths of your updated certificate and key, and click Save.
Then you can use HTTPS to visit 192.168.8.1 or 192.168.8.1:3001.
