How to connect to the dedicated IP by Surfshark on GL.iNet routers?¶
This article introduces the steps to set up the dedicated IP by Surfshark.
Here we take GL-AXT1800 as an example.
Log in to your Surfshark account, select Dedicated IP.
Under the Dedicated IP section, click on Settings.
Select a protocol (WireGuard or OpenVPN) and download config files for manual connection.  For WireGuard Configuration, the download page is as shown below.  For OpenVPN Configuration, the download page is as shown below.  Copy the credentials for later use.
Refer to the links below to upload the configuration files to GL.iNet router. Enter the credentials if required.
