Set Up WireGuard Client on GL.iNet Routers
Note: This guide applies to firmware v4.7 and later. For earlier versions, please refer here.
WireGuard® is an extremely simple yet fast and modern VPN that utilizes state-of-the-art cryptography. It aims to be faster, simpler, leaner, and more useful than IPsec, while avoiding the massive headache. It intends to be considerably more performant than OpenVPN.
To set up WireGuard client on a GL.iNet router, watch this video or refer to the steps below.
GL.iNet routers offer built-in WireGuard support for the following VPN providers. If you have an active subscription, simply enter your service credentials on the WireGuard Client page to finish setup quickly.
Select the corresponding WireGuard service provider below to quickly locate the step-by-step instructions.
If you subscribe to other WireGuard service provider, download a configuration file from their website, then upload the file to your router for VPN connection.
Set Up AzireVPN
AzireVPN is privacy-minded VPN service providing secure, modern and robust tunnels such as WireGuard.
Watch this video to set up AzireVPN on GL.iNet routers via the web Admin Panel or mobile app.
Or follow the steps below to set up AzireVPN via web Admin Panel.
In the web Admin Panel, go to VPN -> WireGuard Client -> AzireVPN.
  1. Enter your AzireVPN Username and Password (i.e., the credentials you use to sign in to AzireVPN), then click Save and Continue. It will generate configuration files for each server.
    azirevpn login
  2. Start a connection.
    Select your preferred server, and click the three-dot icon on the right to start a connection.
    azirevpn start
    Once connected, a green dot will appear next to the configuration file.
    azirevpn connected
    You can also check the VPN connection details on the VPN Dashboard.
  3. Update servers.
    You can click Update Servers to obtain the latest available server list, avoiding connection failures caused by server maintenance or shutdown.
    azirevpn update servers
  4. Edit credentials or logout.
    Click the gear icon to edit your login credentials or log out.
    azirevpn edit credentials or logout
  5. Go renew.
    If you click Go Renew, you will be directed to the official website to renew your subscription.
    azirevpn go renew
  6. Delete All.
    You can click Delete All to delete all configuration files with one click, and choose whether to delete the private and public keys simultaneously.
    azirevpn delete
Set Up Hide.me
Official Website
In the web Admin Panel, go to VPN -> WireGuard Client -> Hide.me.
  1. Enter your Hide.me Username and Password (i.e., the credentials you use to sign in to Hide.me), then click Save and Continue. It will generate configuration files for each server.
    hideme login
    hideme start
    hideme connected
  3. Update servers.
    hideme update servers
    hideme edit credentials or logout
  5. Delete All.
    hide.me delete
Set Up IPVanish
Official Website
In the web Admin Panel, go to VPN -> WireGuard Client -> IPVanish.
  1. Enter your IPVanish Username and Password (i.e., the credentials you use to sign in to IPVanish), then click Save and Continue. It will generate configuration files for each server.
    ipvanish login
  2. Select servers.
    Select the server(s) you want to connect to, and click Apply.
    ipvanish select servers
  3. Start a connection.
    ipvanish start
    ipvanish connected
  4. Update servers.
    ipvanish update servers
  5. Edit credentials or logout.
    ipvanish edit credentials or logout
  6. Delete All.
    ipvanish delete
Set Up Mullvad
Mullvad is a VPN service that helps keep your online activity, identity, and location private.
In the web Admin Panel, go to VPN -> WireGuard Client -> Mullvad.
  1. Enter your Mullvad Account (16-digit number), then click Save and Continue. It will generate configuration files for each server.
    mullvad login
  2. Select servers.
    mullvad select server
    mullvad start
    mullvad connected
  4. Update servers.
    mullvad update servers
    mullvad edit credentials or logout
  6. Go renew.
    mullvad go renew
  7. Delete All.
    mullvad delete
Set Up NordVPN
NordVPN is an online VPN service that combines speed and security.
  1. Click here to log in to your NordVPN web account.
    nordvpn
    After logging in to the Nord dashboard, click NordVPN in the left menu, find the Access Token section, then click Get Access token.
    nordvpn token
    On the next page, click Generate new token.
    nordvpn token
    In the pop-up window, select token expiration date, then click Generate token.
    nordvpn token
    You will then get the access token, as shown below. Copy the token for later use.
    Note: The access token is only displayed once. Make sure you copy and use it now. After closing this window, the token will no longer be visible. If you fail to save it, you will need to generate a new one.
    nordvpn token
  2. Log in to the router's web Admin Panel, and go to VPN -> WireGuard Client -> NordVPN.
    Enter Token, then click Save and Continue. It will generate configuration files for each server.
    nordvpn login
  3. Select servers.
    nordvpn select servers
  4. Start a connection.
    nordvpn start
    nordvpn connected
  5. Update servers.
    nordvpn update servers
  6. Edit credentials or logout.
    nordvpn edit credentials or logout
  7. Delete All.
    nordvpn delete
Set Up PIA (Private Internet Access)
Official Website
In the web Admin Panel, go to VPN -> WireGuard Client -> PIA.
  1. Enter your PIA Username and Password (i.e., the credentials you use to sign in to PIA), then click Save and Continue. It will generate configuration files for each server.
    pia login
  2. Select servers.
    pia select servers
    pia start
    pia connected
  4. Update servers.
    pia update servers
    pia edit credential or logout
  6. Delete All.
    pia delete
Set Up PureVPN
Official Website
PureVPN 15-days free trial
  1. Click here to log in to your PureVPN dashboard.
    purevpn login
    After logging in, click Subscriptions in the left menu, scroll to the bottom to find your credentials. Copy the username and password for later use.
    purevpn credentials
  2. Log in to the router's web Admin Panel, and go to VPN -> WireGuard Client -> PureVPN.
    Enter the copied Username and Password, then click Save and Continue.
    purevpn login
    It will generate all available configuration files.
    purevpn config files
    purevpn start
    purevpn connected
  4. Update servers.
    purevpn update servers
    purevpn edit credential or logout
  6. Delete All.
    purevpn delete
Set Up Surfshark
Official Website
In the web Admin Panel, go to VPN -> WireGuard Client -> Surfshark.
  1. Enter your Surfshark Username and Password (i.e., the credentials you use to sign in to Surfshark), then click Save and Continue. It will generate configuration files for each server.
    surfshark login
  2. Select servers.
    surfshark select servers
    surfshark start
    surfshark connected
  4. Update servers.
    surfshark update servers
    surfshark edit credential or logout
  6. Refresh.
    You can click Refresh to update the public key when the VPN server cannot be connected.
    surfshark refresh
  7. Delete All.
    surfshark delete
Set Up Windscribe
Official Website
In the web Admin Panel, go to VPN -> WireGuard Client -> Windscribe.
  1. Enter your Windscribe Username and Password (i.e., the credentials you use to sign in to Windscribe), then click Save and Continue. It will generate configuration files for each server.
    windscribe login
  2. Select servers.
    windscribe select servers
    Then you will get a list of configuration files corresponding to the selected server.
    windscribe config files
    windscribe start
    windscribe connected
  4. Update servers.
    windscribe update servers
    windscribe edit credential or logout
  6. Refresh.
    windscribe refresh
  7. Delete All.
    windscribe delete
Set Up X-VPN
Official Website
Note: X-VPN is integrated into GL.iNet routers starting from firmware v4.11.
  1. First, obtain X-VPN token on the official website.
    Click here to log in to your X-VPN web account.
    xvpn login
    After logging in, click Settings in the left menu. Find Login Token and click Generate.
    xvpn settings
    The page will generate a token that is valid for 15 minutes. Copy the token for later use.
    xvpn generate token
  2. Log in to your GL.iNet router's web Admin Panel, and go to VPN -> VPN Client Profile. Click X-VPN.
    xvpn enter token
    Enter the token and click Save and Continue.
    xvpn enter token
  3. Select the server(s) you want to connect to, and click Apply.
    xvpn select servers
    xvpn config files
    xvpn start
    xvpn connected
    You can also check the VPN connection details, create and manage VPN tunnels and policies on the VPN Dashboard.
  5. Update servers.
    xvpn update servers
  6. Go renew.
    xvpn renew
  7. Delete configurations.
    Click the gear icon on the right and select Delete Configurations to delete specific or all configuration files with one click.
    xvpn delete
  8. Modify authentication information.
    Click the gear icon on the right and select Modify Authentication Information to edit your login token if necessary.
    xvpn edit credential
  9. Log out.
    Click the gear icon on the right and select Logout to sign out if necessary. It will delete the account credential, associated public key, private key and configuration files stored on the router. Please proceed with caution.
    xvpn logout
Set Up WireGuard Client Manually (for other providers)
If you subscribe to other WireGuard service provider, download a configuration file from their website, then follow the steps below to set up the WireGuard Client. If you don't know how to download the configuration files, refer to this guide or contact their support.
In the web Admin Panel, go to VPN -> WireGuard Client.
  1. Click Add Manually.
    add manually
  2. It will create a group on the left sidebar.
    add a new group
  3. Set a descriptive name for the group (e.g., azirevpn). Then upload a configuration file (supported formats: zip, tar, gz, conf, txt) or manually add configuration details (in text form).
    set the new group name
    1. Upload a configuration file.
      Click on the upload area to upload your WireGuard configuration file, then click Apply.
      upload profile
      after upload profile
    2. Manually add configuration.
      Click on Manually Add Configuration at the bottom of the upload area.
      add wireguard by text
      Set a descriptive name, and paste the configuration into the text box. Then click Apply.
      add wireguard by text (Text Mode)
      If you want to verify each item, you can switch to the Item mode and check the config details. Then click Apply.
      add wireguard by item mode (Item Mode)
  4. Click the three-dot icon on the right side to start the connection.
    start the profile
Set Up WireGuard Client via Mobile App
You can also set up a WireGuard client via the mobile app.
The mobile app integrates some WireGuard service providers, such as AzireVPN, Mullvad VPN, OVPN, StrongVPN, and PIA VPN. You can easily set up a WireGuard client by entering the login credentials of the WireGuard service you subscribed to.
Install the app and follow the on-screen instructions to set up as needed.
Set Up WireGuard Server on GL.iNet Router
Do not want to subscribe to third-party VPN services? You may purchase two GL.iNet routers – set one as WireGuard server and the other as WireGuard client.
This is especially suitable for scenarios where your home network's ISP provides a Public IP, and you want to connect to your home network via VPN when away from home to ensure security and access to internal network resources. This eliminates the cost and hassle of continuously subscribing to commercial VPN services.
For WireGuard server setup, please check here.
