Setup WireGuard on GL.iNet router
WireGuard is an extremely simple yet fast and modern VPN that utilizes state-of-the-art cryptography. It aims to be faster, simpler, leaner, and more useful than IPSec, while avoiding the massive headache. It intends to be considerably more performant than OpenVPN.
GL.iNet routers have pre-installed WireGuard Server and Client.
If you are looking for a WireGuard provider, check out this directly.
We can setup WireGuard Client via web Admin Panel and mobile app. For the mobile app, it has already integrated some WireGuard Service Providers, they are AzireVPN, MullvadVPN, OVPN, WeVPN, StrongVPN, PIA VPN, SpiderVPN.
For setup via web Admin Panel, please follow the guide below.
Setup WireGuard Client
There is a video tutorial, please check out here.
To setup a WireGuard Client, please click + Set up WireGuard Manually.
Input the configuration
There are different methods to input the configuration.
For AzireVPN and MullvadVPN users, please choose the Providers tab, for more detail, access here.
You can paste the configuration on Configuration tab, or create from scratch on Manual Input tab.
Specify the name of your server
Specify a descriptive name and then click Next.
Choose the server and click Connect.
If connected, it will show the traffic info of upload and download .
Note that you can't running VPN Client and Server at the same time, and also can't running OpenVPN Client and WireGuard Client at the same time.
WireGuard Providers
If you are using AzireVPN or Mullvad, it has integrated their services.
AzireVPN
Select AzireVPN as the provider, enter your User Name and Password and then click `Next`.
It will take several minutes to get configs, please be patient.
Mullvad
Select Mullvad as the provider, enter your Account Number and then click "Add" to finish the WireGuard Client setup.
Other recommended WireGuard provider:
Windscribe
Login then access the WireGuard Config Generator. Select location and port you'd like to use, then click Download Config.
Open it by a text editor, copy the content.
Login web Admin Panel, VPN --> WireGuard Client --> Set up WireGuard Manually
Paste the configuration text to the Configuration windows. Click Next
Specify the name of your server and click Add
Connect to the WireGuard server by clicking Connect
You will see the upload and download traffic when it is connected successfully.
StrongVPN
If you are using StrongVPN, sign in at https://wg.strongvpn.com
Select a location from the drop down menu, click GENERATE, open the downloaded text file.
Open the config by text edit software, copy the content.
OVPN
Login www.ovpn.com, find the menu below to get WireGuard configuration files.
Click Generate WireGuard keys, choose the server you wanted, then download the config.
The config may contain IPv6 content, as GL.iNet routers is not support IPv6 good enough, so please delete the IPv6 content. I have a example show below, the highlight content is the IPv6 content.
PrivateVPN
Login then access the Control panel
Select a server
Click GENERATE CONFIG, then copy the config.
IVPN
If you are using IVPN, you need to generate the WireGuard config manually. Follow the guide base on your OS.
After generated the config, copy it.
NVPN
Fellow the guide here to create the config.
SpiderVPN
Login www.spidervpn.org, find the section to get your VPN configuration. Follow the steps to get the configuration.
Download the vpn configuration
Paste the configuration text to the Configuration windows. You need to adjust the format, make sure there is a space on each side of the equals sign. Click Next
TRUST.ZONE
Access https://trust.zone/setup and login
Scroll down to the WireGuard section, choose the port you want, then download a config of specific server or a zip file of all configs
Extract and open it by a text editor, copy the content.
VPN.AC
If you are using VPN.AC, you need to login the control panel and find WireGuard Manager from the "Services" menu.
Create the config and download.
Extract file, open the config by text edit software, copy the content.
VPN Unlimited(KeepSolid)
If you are using VPN Unlimited, sign in to your User Office > select the VPN Unlimited® application > click Manage.
Press the field under Device and click Manually create a new device… > set it’s custom name, for example WireGuard > choose appropriate location of the Server > select the WireGuard® protocol from the dropdown menu > click Generate.
The configuration parameters will then appear below in the text format. You’ll need them for further configuration of your GL.iNet router.
The Add a New WireGuard® Client window will appear. In the Configuration tab, paste the details of the manual configuration settings you’ve generated before:
[Interface] PrivateKey = paste the PrivateKey from your User Office ListenPort = paste the ListenPort details Address = paste Address information DNS = paste DNS details from the User Office [Peer] PublicKey = paste PublicKey from the User Office PresharedKey = paste PresharedKey details AllowedIPs = paste AllowedIPs details Endpoint = paste Endpoint information
Once completed, click Add.
12VPX
If you are using 12VPX, login then access this page, you will see the configs of all servers.
Copy the WireGuard config.
Suggest a WireGuard provider? Please contact support@gl-inet.com
Click Connect. You will see the upload and download traffic when it is connected successfully.
Video Tutorial
How to Set Up an WireGuard Client on GL.iNet Routers
