How to check if Internet Service Provider assigns you a public IP address?¶
What is Public IP address?¶
All IPv4 addresses can be divided into two major groups: global (or public, external) — those that are used on the Internet, and private (or local, internal) addresses — those that are used in the local area network (LAN).
A public IP address is an IP address that is used to access the Internet. Public IP addresses can be routed on the Internet, unlike private addresses.
The presence of a public IP address on your router will allow you to organize your own server (VPN, FTP, WEB, etc.), remote access to your computer, video surveillance cameras, and get access to them from anywhere on the global network.
Method 1:¶
Ask your Internet Service Provider directly.
Method 2:¶
Check the two IP address below to see if they are the same, otherwise not.
Search my ip address on Google, or access website like https://tool.gl-inet.com/ip
Access the main router, you can find the WAN IP address.
If the main router is GL.iNet router, the WAN IP address is the IP Address on the Internet page.
