Dual-Ethernet WAN
Supported models
Router Model Support
GL-MT6000 (Flint 2)
GL-XE3000 (Puli AX)
Setup
You can use the function change to WAN at the internet tab to change one more LAN port to WAN.
dual ethernet wan
After you enable Dual-Ethernet WAN, you can configure multi-wan functions here.
