How to connect USB TTL¶
To connect a USB TTL device:
- Insert the USB TTL adapter into one of the USB ports on the KVM device.
- Use the following command to connect to the USB serial port:
minicom -D /dev/ttyUSB0 -b 115200
This command connects to the USB serial device at /dev/ttyUSB0 with a baud rate of 115200.
