How to access serial console via USB TTL¶
Follow the steps below to use the USB TTL adapter for serial debugging:
- Plug the USB TTL adapter into the USB port of your KVM device.
- Run the following command to open the serial port connection:
minicom -D /dev/ttyUSB0 -b 115200
This command establishes serial connection to /dev/ttyUSB0 at a baud rate of 115200.
Last update:
June 2, 2026
