Comet X (GL-RM4PE) User Guide¶
Comet X is a quad-port remote KVM with PoE support that connects to up to 4 servers in your rack. Once set up, you can control all connected devices from anywhere via a browser or app, delivering smooth 4K@30fps video without extra software. Its built-in 3.69 inch touchscreen lets you check IP addresses, online status, and active sessions at a glance. It simplifies deployment with PoE power, reducing cable clutter in your server environment. The 64GB eMMC storage also acts as a built-in repository for ISO files, enabling easy OS deployment and emergency recovery.
Last update:
August 4, 2026
