How to record remote screen
You can capture the screen of the controlled device and store the video file locally on your KVM device.
Run the following command via SSH to start screen recording:
ustreamer-dump --sink kvmd::ustreamer::h264 --output - | ffmpeg -use_wallclock_as_timestamps 1 -i pipe: -c:v copy /userdata/media/my_video.mp4
The recorded videos will be saved to this directory:
You can transfer and download the video file via the Virtual Media feature.
Last update: June 2, 2026
