How to connect to NordVPN with a dedicated IP on GL.iNet routers?¶
This article introduces the steps to set up a NordVPN connection with a dedicated IP on GL.iNet routers.
We use the GL-AXT1800 as an example.
Log in to your Nord Account and check the dedicated IP details. As shown below, the assigned IP is 193.32.211.142, and the server is United Kingdom #1625.
Go to https://nordvpn.com/ovpn/ and find the configuration file for United Kingdom #1625. Download the UDP or TCP configuration file.
Return to your Nord Account page, go to Manual Setup and click Set up NordVPN Manually to get your service credentials.
Log in to your router's web Admin Panel and go to VPN > OpenVPN Client. Create a new group and upload the configuration file downloaded in Step 2, then enter the service credentials obtained in Step 3.
As shown above, a valid configuration file has been detected. Enter your NordVPN service credentials.
Click the three-dot icon on the right to connect. You may also go to VPN Dashboard, select the configuration file and click Apply to establish a connection.
Once connected, check your public IP here and confirm if it matches your dedicated IP from NordVPN.
