Firmware v4.9¶
This release focuses on more precise network control, improved traffic management, enhanced network security, and a revamped user interface — all designed to deliver a better overall user experience.
Get the latest firmware from the Firmware Download Center.
Flow Control¶
Flow Control is a core network management module that enables precise identification, monitoring, regulation and filtering of network traffic, effectively optimizing network resource allocation, eliminating bandwidth congestion, and standardizing network access behaviors to deliver a smoother, safer and more controllable network experience. In firmware v4.9, this module integrates with multiple practical functions for comprehensive traffic management.
The Flow Control module includes DPI Engine, Data Statistics, Content Filter, QoS, SQM, and Parental Control.
DPI Engine¶
Unlike traditional routers that only identify source and destination addresses, DPI (Deep Packet Inspection) performs in-depth analysis of packet payloads and accurately identifies applications and websites using a feature-matching library, enabling fine-grained traffic classification and control.
Integrated with Netify, GL.iNet DPI adopts a lightweight embedded plug-in for efficient deployment. With Netify's online-updated signature database, it enables reliable management, making network control more accurate and efficient.
Data Statistics¶
Data Statistics provides an intuitive traffic dashboard that identifies network usage by application and protocol. It supports viewing 1‑hour, 1‑day, and 7‑day historical trends, displays usage rankings, monitors per‑device traffic, and allows one‑click blocking of unwanted apps.
Content Filter¶
Content Filter is an intelligent online safety feature powered by DPI classification. It automatically blocks harmful and malicious websites to keep your network clean and secure, and also supports custom rules to block specific apps, domains, or IP addresses.
QoS¶
QoS (Quality of Service) optimizes bandwidth allocation by prioritizing critical activities (e.g., video calls, gaming) during network congestion, reducing latency and improving overall network performance.
SQM¶
SQM (Smart Queue Management) intelligently manages your router's network traffic to minimize latency and "bufferbloat", ensuring smoother gaming and voice calls.
Parental Control¶
Parental Control was previously categorized under the Applications menu. It is migrated to the Flow Control menu in firmware v4.9, as it leverages the upgraded DPI engine to accurately identify and block inappropriate applications and network content, achieving more professional and precise traffic-based access restriction.
VPN¶
Firmware v4.9 has comprehensively improved the underlying routing logic and interactive interface of the VPN module, fixing potential routing conflicts, simplifying configuration logic, and improving operational intuitiveness.
The detailed adjustments are as follows.
Isolated VPN Tunnel¶
Each VPN tunnel operates as an independent group without cross-group failover. Once the network traffic matches to a specific VPN group, it will not automatically switch to other VPN groups even if the current tunnel fails, ensuring stable and predictable traffic routing.
Note: The traditional "Not Use VPN" policy is removed in firmware v4.9, eliminating redundant configuration to avoid routing conflicts caused by multiple and complex tunnel rules.
VPN Profile Failover¶
A single VPN tunnel group can accommodate multiple configuration profiles. Users can customize the priority of each profile within the same group, enabling automatic internal failover to maintain continuous VPN connectivity when a single profile fails.
Redesigned Dashboard¶
The VPN Dashboard in firmware v4.9 features a complete redesign for a more intuitive layout. Tunnel status, connection details, and configuration entries are presented for clearer visibility, significantly boosting day‑to‑day operational and management efficiency. In addition, Kill Switch is enabled by default for all VPN tunnels under the new architecture to keep your traffic protected at all times.
AmneziaWG 2.0¶
Firmware v4.9 officially introduces the AmneziaWG 2.0 protocol, equipped with multiple new traffic obfuscation parameters. The upgraded protocol effectively evades detection by DPI and other traffic identification systems, significantly improving connection concealment and anti-interference capabilities. This enables stable and reliable VPN connection establishment in network-restricted regions and complex network environments.
IoT Network¶
The IoT Network in firmware v4.9 allows you to create an independent dedicated Wi-Fi network for IoT smart devices. Physically and logically isolated from the primary network, it avoids network resource occupation and security risks brought by IoT device access to the main network. This optimization delivers broader device compatibility for various smart IoT clients and overall enhances the home network security system.
ACL¶
ACL, short for Access Control List, is a core network security management feature that allows users to create customized access rules to manage internal and external network traffic based on connection protocols, device IP addresses, and port. It supports precise permission control to allow or block specific network access behaviors. When multiple ACL rules generate conflicts, the system automatically executes the rule with higher priority to ensure accurate policy implementation.
Distinguished from Port Forwarding in core positioning, ACL focuses on network security management by controlling device and traffic access permissions; while Port Forwarding is used for network resource redirection, forwarding external network traffic to specified local terminal devices to implement remote access to local network services.
Wireless¶
The Wireless UI is fully redesigned with a streamlined layout and unified visual style, reducing operational complexity and greatly improving overall interface simplicity and user-friendliness.
Encrypted DNS¶
The Encrypted DNS is expanded to cover more encryption protocols including DoH, DoT and DoQ. Meanwhile, more official DNS service providers are integrated, and the manual configuration for custom encrypted DNS servers is added to meet diverse secure domain resolution demands.
Tailscale Exit Node¶
GL.iNet routers now support running as a Tailscale exit node. All outbound internet traffic from devices in the Tailnet can be routed through the router's public IP address, realizing unified and secure network exit management for the entire Tailscale network. Please refer to here for details.
