Parental Control (Firmware v4.9)
Note: This guide applies to firmware v4.9 and above. For earlier versions, please click here.
On the left side of the web Admin Panel, go to FLOW CONTROL -> Parental Control.
Parental control protects children online by blocking inappropriate websites and limiting screen time. It filters harmful content and encourages responsible internet usage.
GL.iNet Parental Control provides flexible scheduling to restrict internet access on your children's commonly used devices. You can block inappropriate apps and websites in one click. Additionally, you may enter domains manually as needed to achieve full online protection.
Follow the steps below to set up Parental Control.
  1. Log in to the router's web Admin Panel and go to FLOW CONTROL -> Parental Control. Ensure the router time is accurate.
    router time
    If not, go to SYSTEM -> Time Zone to synchronize it first.
  2. Enable Parental Control and click Apply.
    enable
  3. You will see a rule list as follows. Click Add a New Rule.
    add a new rule
  4. In the pop-up window, create a rule and set a custom name, then click Next.
    create a rule
  5. Select your child's device, then click Next.
    A device will only appear on this page if it is connected to the router via Wi-Fi or Ethernet. Cyan indicates online status, while grey indicates offline status.
    select device
    Tip: If you want to distinguish the connected devices, go to CLIENTS page and customize device names.
  6. Set bedtime for your child's device, then click Next.
    The internet on the selected device(s) will be unavailable during this period. By default, the bedtime is the same for every day.
    bedtime1
    If you want to set different bedtimes for each day of the week, select Customize Days and set different bedtimes, then click Next.
    bedtime2
  7. Select content filter.
    Three categories have been selected by default: Gambling, Malicious Content, and Sexual Content. You may select other categories if needed, such as Games, Shopping, Social Media, Entertainment, etc.
    content filter
    If a certain app you want to block is hard to find out, search it on the top to quickly locate it.
    search app
  8. If you need to block certain domains, click Advanced Settings at the bottom right.
    block domain1
    Enter domains manually, then click Finish.
    block domain2
  9. The rule is now added. The list shows the rule name, connected device count, bedtime schedule, filtered content and rule status (enabled/disabled).
    rules added
    You can perform basic operations on the existing rules: Modify, Copy and Delete.
    action
    • Modify: Change selected devices, bedtime and content filter rules.
      action modify
    • Copy: Create a copy of an existing rule to avoid reconfiguring manually.
      action copy
