Understanding external cellular antennas¶
External cellular antennas can improve the quality of your cellular connection in certain situations, but they are not guaranteed to increase download or upload speeds.
This guide explains when an external antenna may help, how to choose a compatible antenna, and what factors affect cellular performance.
When should I use an external antenna?¶
An external antenna may improve your connection if your router is installed in a location where cellular signals are weakened before reaching the device.
Typical examples include:
- RVs and campers
- Vehicles
- Basements
- Buildings with concrete, brick, or metal walls
- Utility rooms or network cabinets
- Rural locations with weak cellular coverage
Before purchasing an antenna, try moving the router closer to a window or to a higher location. In many cases, relocating the router alone can significantly improve signal quality.
When won't an external antenna help?¶
An external antenna cannot solve every cellular connectivity issue.
It may provide little or no improvement if:
- The router already has a strong cellular signal.
- The cellular tower is congested.
- Your mobile carrier is limiting network speeds.
- The antenna does not support your carrier's frequency bands.
- Long antenna cables introduce excessive signal loss.
- The antenna is installed in nearly the same location as the router's internal antennas.
A stronger signal does not always result in faster internet speeds.
Choosing the right antenna¶
Before purchasing an antenna, make sure it is compatible with both your router and your mobile carrier.
Verify the following:
- The connector type matches your router.
- The antenna supports the cellular frequency bands used by your carrier.
- The antenna is designed for LTE, 5G, or both, depending on your router.
- The antenna is suitable for your installation environment (indoor, vehicle, outdoor, etc.).
Refer to your router's product documentation for the correct antenna connector type.
Understanding MIMO¶
Most modern LTE and 5G networks use Multiple Input Multiple Output (MIMO) technology to improve throughput and connection reliability.
Many GL.iNet cellular routers include multiple cellular antenna ports to support MIMO.
For the best performance:
- Connect all required antenna leads.
- Use a compatible MIMO antenna whenever possible.
- Follow the antenna manufacturer's recommendations for antenna spacing and orientation.
Using only one antenna on a router designed for multiple antennas may reduce overall performance.
Antenna gain and cable loss¶
Antenna gain is typically measured in dBi.
Higher gain does not always mean better performance.
Higher-gain antennas usually become more directional, making them suitable for fixed installations where the serving cellular tower is known.
Cable length is equally important. Every antenna cable introduces signal loss before the signal reaches the router.
For best results:
- Use the shortest practical cable.
- Avoid unnecessary adapters.
- Use low-loss coaxial cable for longer cable runs.
Omnidirectional vs. directional antennas¶
Omnidirectional antennas¶
Omnidirectional antennas receive signals from all directions.
They are generally recommended for:
- Vehicles
- RVs
- Mobile installations
- Areas with multiple nearby towers
Directional antennas¶
Directional antennas concentrate reception toward a specific direction.
They are generally recommended when:
- The router remains in one location.
- The serving cellular tower is known.
- Cellular coverage is weak.
- Maximum signal quality is required.
Directional antennas usually require careful alignment for the best performance.
Measuring improvement¶
Do not rely only on the signal bars shown in the router interface.
Compare signal measurements before and after installing the antenna.
Useful measurements include:
- RSRP (signal strength)
- RSRQ (signal quality)
- SINR (signal-to-interference ratio)
- Connected LTE or 5G band
- Carrier aggregation status
Run several speed tests under similar conditions, as cellular performance naturally changes throughout the day.
Frequently asked questions¶
Can I use any cellular antenna?¶
No.
The antenna must use the correct connector type and support the cellular frequency bands used by your router and mobile carrier.
Should I buy the highest-gain antenna available?¶
Not necessarily.
Choose an antenna that is appropriate for your installation rather than selecting one based only on its advertised gain.
Will an external antenna always increase my internet speed?¶
No.
Performance depends on many factors, including signal quality, carrier aggregation, tower congestion, network conditions, and your mobile carrier.
Will the internal cellular antennas still be used when external antennas are connected?¶
No.
On GL.iNet cellular routers with external cellular antenna ports, connecting compatible external antennas disables the corresponding internal cellular antennas.
For the best performance, connect all required external antenna leads. Connecting only one lead to a router designed for multiple cellular antennas may reduce MIMO performance and overall connection quality.
Can I connect a Wi-Fi antenna to a cellular antenna port?¶
No.
Wi-Fi and cellular antennas are designed for different radio systems and are not interchangeable.
Related tutorials¶
